ddewrbbdg
Jun 03, 2024Guide
Cant install MySQL addon cause missing repo or packages, please help
Hi, i have very same problem with installing mySQL. PHP install went ok. Altough i have to downgrade from 6.10.10 to 6.10.9 cause apps were otherwise unavailable to get. I have tried both ways, inst...
ddewrbbdg
Jun 04, 2024Guide
Ok, thank you, i have used guide you refered to and posted link
Succesfully installed php, also mysql.. but now im fighting with the following.. its regarding PHPMyAdmin
root@NAS:/data/pictures# apt-get install /data/pictures/phpmyadminr6_4.0.4_all.deb --fix-missing
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'phpmyadminr6' instead of '/data/pictures/phpmyadminr6_4.0.4_all.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
phpmyadminr6 : Depends: php5-mysql (>= 5.4.4-13)
Depends: php5-mcrypt (>= 5.4.4-13) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
ddewrbbdg
Jun 09, 2024Guide
Ok, looks like the solution i have found was
manually (re)install both packages with
apt-get install php5-mysql
apt-get install php5-mcrypt
and reconfigure php.ini
Now i have PHP + MySQL + PHPMyadmin installed. Going to try out whether it workks (uploading files, creating dbs, administration of database, accesing from public network).
