Idward
May 12, 2021Aspirant
ClamAV is not updating. Error 503
I am getting regular emails about my readynas' AV being out of date. I logged on and ran freshclam getting back ClamAV update process started at Wed May 12 11:31:09 2021 WARNING: Your ClamAV in...
- May 21, 2021
Hi @Sandshark,
We are still investigating why the AV database is still not updating for some users even after updating to 6.10.5.
For this particular case, L3 checked /var/lib/clamav and saw that daily.cld was still outdated. L3 needs to renew it so they removed the two files (daily.cld and mirrors.dat) then ran freshclam.
If the user is knowledgeable in Linux, they can try this, but it will be best if they can send the logs to me or @Marc_V so we can forward this to the appropriate team and they can further investigate the issue
Idward
ReadyNAS 2304
Firmware 6.10.4 Hotfix 1.
I hit the check for updates and it gave me an "you are all up to date" message.
JohnCM_S
May 12, 2021NETGEAR Employee Retired
Hi Idward,
You can try manually updating the firmware to 6.10.5. You may download the firmware here: https://kb.netgear.com/000063642/ReadyNAS-OS-6-Software-Version-6-10-5.
- IdwardMay 12, 2021Aspirant
I upgraded to 6.10.5. and that did not fix it, still getting an error
Now, worringly, it will not let me connect to the admin web page. It gives me the password prompt then goes through the "Connecting to ReadyNAS Admin Page" and kicks out with a timeout error.
Fortuantly, I can still ssh into it and access the file server, though RAIDar 6.5.0 does not pick it up.
- JohnCM_SMay 12, 2021NETGEAR Employee Retired
Hi Idward,
Have you tried rebooting the NAS?
If you are still not able to access the admin page or if the NAS is still not detected on RAIDar even after rebooting it, you can also try doing an OS reinstall and see if that helps.
The only thing I can think is maybe the bond is causing an issue?
Is there a way to do the OS reinstall from the commandline?
I don't think would delete anything from the disk but I wanted to be sure.
