arnomc
Oct 27, 2013Aspirant
Contacts&Calendars for RN6: Baikal & iOS no cardDAV sync !!
Has anyone tried this add-on based on Baïkal ? I installed it and then configured it with success on OS X (Mavericks) for both CalDAV and CardDAV (http without SSL). I also figured it out on iPhone f...
arnomc
Feb 27, 2014Aspirant
How can I didn't notice your answer before! Thanks for the advice sjuul :)
When I tried this add-on on november, I had a look on the address but it's been few month so I don'tremeber if it was doing the 'double address' you told me. I tried again today and I noticed what you explained me : this is definitively a potential source of failure. Still, taking care of it didn't sync my iOS to Baikal :( (Baikal syncs correctly with OS X).
But the example address you wrote contains difference compare to the one given by Baïkal add-on made by NETGEAR :
"Server: ipaddress:7500/card.php(note: no http:// nor https://, and no trailing slash) "
- you didn't specify the port ? and you insert a "baikal-flat" ?
- so I am wondering if you installed this addon yourself via a command line or did you install netgear's package from OS6 interface ? (maybe it's a stupid question, but I tried so many solutions without success... it's getting me crazy :x )
Thanks for your help.
Note : I also heard about the SSL 'false' warning that we should rejected so it should sync with SSL, isn't it? I am asking because when I'll have a working card sync I would like to sync with SSL to replace my local ip by my domain name (to be able to sync from outside my homeLAN).
