livingem2
Jun 02, 2014Aspirant
HELP INSTALLING PLEX PLEASE
Hello I have a ReadyNAS 6 operating system, with PLEX installed. The dashboard disappeared and then the program stopped working. I removed the add-on and am now trying to reinstall it. I have locat...
mdgm-ntgr
Jun 02, 2014NETGEAR Employee Retired
So you are running RAIDiator 4.2.x not ReadyNAS OS 6 (I assumed from your first post that you were probably running OS6). You need the Intel 4.x .bin file which you could install via Add-ons > Add New in Frontview.
The NAS checks the file you attempt to install to make sure it is right for your system and that it is not corrupt before attempting to install it.
