devbobo's avatar
devbobo
HOW TO: Hosting multiple websites
G'day Guys,
For some time I've wanted to host multiple websites from a single ReadyNAS unit...I haven't had the time to investigate it.
1. Backup all the .conf files in /etc/frontview/apache
2. Backup all the .conf files in /etc/frontview/apache - so you can restore the originals if you screw something up !!!
3. Edit /etc/frontview/apache/Virtual.conf
Original file
<VirtualHost _default_:80>
SSLEngine off
RewriteEngine on
RewriteRule ^/admin/(.*)$ https://%{SERVER_NAME}/admin/$1 [R,L]
</VirtualHost>
Modified file
NameVirtualHost *:80
<VirtualHost *:80>
SSLEngine off
RewriteEngine on
</VirtualHost>
4. Create a new my-virtual.conf file in /etc/frontview/apache/addons, this way it will be auto loaded without modifying any other files. The example below has definitions for two websites....add/remove as required.
my-virtual.conf
<VirtualHost *:80>
ServerName www.example.com
DocumentRoot /path/to/example.com
<Directory /path/to/example.com>
Options Indexes
Order allow,deny
Allow from all
</Directory>
<Location /index.html>
SetHandler none
Order Allow,Deny
Allow from all
</Location>
SSLEngine off
</VirtualHost>
<VirtualHost *:80>
ServerName www.domain.net
DocumentRoot /path/to/domain.net
<Directory /path/to/domain.net>
Options Indexes
Order allow,deny
Allow from all
</Directory>
SetHandler none
Order Allow,Deny
Allow from all
</Location>
SSLEngine off
</VirtualHost>
5. shutdown apache, killall apache-ssl
6. restart apache, apache-ssl -f /etc/frontview/apache/httpd.conf
7. All done :D
CAVEATS
1. Toggling the state of HTTP within Frontview rewrites Virtual.conf so the above changes will be lost.
ReadyNAS Team
1. It would be nice if the above changes could be made to the format of /etc/frontview/apache/Virtual.conf, so that changes aren't overwritten
2. I currently have to add the Location element to undo a global definition within httpd.conf. It would be awesome if this was removed from httpd.conf and added to Virtual.conf as...
<VirtualHost *:80>
SetHandler server-status
Order Deny,Allow
Deny from all
</Location>
SSLEngine off
RewriteEngine on
</VirtualHost>
Cheers,
David
  • Stefan,
    I tried re-applying your patch. Here is how:
    alfa-nas:/etc/frontview# ls apache.bak/ #<--- Config before apply WhoCares?'s patch
    04d1e7c3.0 addons apache.pem Auth.conf httpd.conf Ports.conf Shares.conf Shares.conf.1 Shares.conf.2 ssleay.cnf Virtual.conf
    alfa-nas:/etc/frontview# ls apache.add/ #<--- Pulled from Gitorious
    Auth.conf AuthVhost.conf DefAlias.conf httpd.conf PerlSettings.conf Ports.conf ssleay.cnf Virtual.conf
    alfa-nas:/etc/frontview# rm -rf apache
    alfa-nas:/etc/frontview# cp -rf apache.bak/ apache
    alfa-nas:/etc/frontview# cp -rf apache.add/* apache
    alfa-nas:/etc/frontview# ls apache.upd/sites/ #<--- My custom *.vhost files
    2011cc.otzo.com.vhost leoj3n.no-ip.org.vhost leoj3n.otzo.com.vhost mom.otzo.com.vhost
    alfa-nas:/etc/frontview# cp apache.upd/sites/*.vhost apache/addons/
    04d1e7c3.0 apache.pem AuthVhost.conf httpd.conf Ports.conf Shares.conf.1 ssleay.cnf
    addons Auth.conf DefAlias.conf PerlSettings.conf Shares.conf Shares.conf.2 Virtual.conf
    alfa-nas:/etc/frontview# ls apache/addons/
    2011cc.otzo.com.vhost leoj3n.no-ip.org.vhost mom.otzo.com.vhost PHPMYADMIN.conf RSNAPSHOT.conf
    DNSOMATIC.conf leoj3n.otzo.com.vhost phpadmweb.conf PLEXMEDIASERVER.conf
    alfa-nas:/etc/frontview# apache-ssl -f /etc/frontview/apache/httpd.conf -k restart -V
    Server version: Apache/2.2.6 (Debian)
    Server built: Feb 28 2008 22:43:28
    Server's Module Magic Number: 20051115:5
    Server loaded: APR 1.2.7, APR-Util 1.2.7
    Compiled using: APR 1.2.7, APR-Util 1.2.7
    Architecture: 32-bit
    Server MPM: Prefork
    threaded: no
    forked: yes (variable process count)
    Server compiled with....
    -D APACHE_MPM_DIR="server/mpm/prefork"
    -D APR_HAS_SENDFILE
    -D APR_HAS_MMAP
    -D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
    -D APR_USE_SYSVSEM_SERIALIZE
    -D APR_USE_PTHREAD_SERIALIZE
    -D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
    -D APR_HAS_OTHER_CHILD
    -D AP_HAVE_RELIABLE_PIPED_LOGS
    -D DYNAMIC_MODULE_LIMIT=128
    -D HTTPD_ROOT=""
    -D SUEXEC_BIN="/bin/suexec"
    -D DEFAULT_PIDLOG="/var/run/apache2.pid"
    -D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
    -D DEFAULT_LOCKFILE="/var/run/apache2/accept.lock"
    -D DEFAULT_ERRORLOG="logs/error_log"
    -D AP_TYPES_CONFIG_FILE="/etc/apache2/mime.types"
    -D SERVER_CONFIG_FILE="/etc/apache2/apache2.conf"
    Just trying to eliminate any possible causes of the problems I am still facing. Any ideas? :(
  • leoj3n wrote:
    Changing from /sites/ to /addons/ was fruitless. However I tried going to http://2011cc.otzo.com/index.php which gives the output:
    Your server is running PHP version 5.2.0-8+etch16 but WordPress 3.4.1 requires at least 5.2.4.
    However if you don't go directly to the index.php file you still get the permissions thing: http://2011cc.otzo.com/
    An update: I finally thought to remove the .htaccess included with (correction: generated by, because I copied the WordPress files from my Desktop which was running a webserver and active WordPress install) WordPress and now the permission error goes away when you visit http://2011cc.otzo.com/
    Going to http://2011cc.otzo.com/ does a directory-listing however, and doesn't automatically query index.php - that is what I will work on next.
    Update: I had removed the following from the custom .vhost file during testing:
      <Location />
    DirectoryIndex redirect.html index.html index.htm index.php
    </Location>
    Adding it back causes index.php to be downloaded when visiting http://2011cc.otzo.com/ or http://2011cc.otzo.com/index.php ...
  • My best guess right now is that by jsut copying over the existing files some fragments still interfere with the general operation of your Apache config. Try removing the apache config dir completey (of course only after you've made yet another backup ;)) and copy over the x86 config from the gitorious repo. Then copy back the add-on subdir. Also, if I'm not completely mistaken there should be an installer script in the repo, no?
    -Stefan
  • Unfortunately I totally missed the install.sh script when I started this whole charade. I just copied the x86 dir using cp, and that's what I've been doing up until this point. Sorry for my ignorance, I've never run a .sh file until today.
    To attempt to start from scratch I did the following, please look this over (apache.bak is the backup of the original /apache/ folder, made before doing any modifications):
    apache-ssl: Could not reliably determine the server's fully qualified domain name, using 10.0.1.2 for ServerName
    alfa-nas:/etc/frontview# cd /c/home/admin/System\ Stuff/NAS/apache-configs/
    alfa-nas:/c/home/admin/System Stuff/NAS/apache-configs# sudo bash install.sh
    Syntax OK
    alfa-nas:/c/home/admin/System Stuff/NAS/apache-configs# cd -
    /etc/frontview
    alfa-nas:/etc/frontview# cp apache.upd2/addons/2011cc.otzo.com.vhost apache/addons/
    alfa-nas:/etc/frontview# cat apache/addons/2011cc.otzo.com.vhost
    <VirtualHost *:80>
    ServerName 2011cc.otzo.com
    ServerAlias 2011cc.otzo.com
    DocumentRoot /c/public_html/2011cc
    #LoadModule php5_module /usr/lib/apache2/modules/libphp5.so
    #AddHandler php5-script .php
    #AddType text/html .php
    #AddType application/x-httpd-php .php
    #AddType application/x-httpd-php-source .phps
    <Directory /c/public_html/2011cc>
    Options +FollowSymLinks +ExecCGI
    AllowOverride All
    Order Allow,Deny
    Allow from all
    </Directory>
    <Location />
    #Options ExecCGI
    </Location>
    SetHandler none
    Order Allow,Deny
    Allow from all
    </Location>
    SSLEngine off
    RewriteEngine On
    RewriteOptions Inherit
    </VirtualHost>
    PHP files are still being downloaded instead of output to the browser. I even tried restarting the NAS (just for fun?) but the problem persists.
    Thanks for all your attention Stefan. Does your config on your server serve up PHP files correctly? If so I think we can narrow this down to php_mod being installed incorrectly. At that point I will probably try using your FrontView PHP add-on.
  • Actually my config does nothing to allow/prevent PHP scripts from being executed / served to the user. This should be handled by the libapache2-mod-php5 module. Unfortunately this will add it's config to a file that isn't read by the ReadyNAS' Apache web server. What you can try to do is to create the file '/etc/frontview/apache/addons/00_phpload.conf' with this contents:
    <IfModule mod_php5.c>
    </IfModule>
    Restart Apache and see whether this changed anything.
    -Stefan
  • No, no changes. In the custom vhost I tried
    <Location />
    </Location>
    and
    <Location />
    Options ExecCGI
    </Location>
    but that had no effect either. When I visit http://2011cc.otzo.com/ it still just downloads the damned PHP file. :evil:
    The output of apache-ssl -f /etc/frontview/apache/httpd.conf -M contains no references to php.
  • Stefan (WhoCares?) helped me privately and we got it sorted. I posted the critical factor here: viewtopic.php?f=35&t=64537
    Here's my final config, it should be useful to anyone else trying to set up virtual hosts + PHP (& I've included an example that fixes directory images): http://leoj3n.otzo.com/example-apache-a ... fig.tar.gz
    Important files:
    /etc/frontview/apache/addons/sub.domain.com.vhost #example virtual host
    /etc/frontview/apache/addons/dirlist.domain.com.vhost #example virtual host that supports directory images
    /etc/frontview/apache/addons/domain.com.vhost #example virtual host that utilizes ServerAlias
    /etc/frontview/apache/addons/00_php5module.conf #php5 config file; without this .php files download instead of output to the browser
    Here are the steps the I believe resulted in my eventual success:
    First, backup your current configuration
    cp -rf /etc/frontview/apache/ /etc/frontview/apache.bak/
    Change settings in FrontView -> Standard File Protocols -> HTTP
    Redirect default web access to this share: None selected
    Login authentication on this share: Disable
    Clone WhoCares?'s apache-configs repo on Gitorious
    Link: https://gitorious.org/readynas/apache-configs
    Git clone command:
    git clone git://gitorious.org/readynas/apache-configs.git apache-configs
    Run the apache-configs install file
    cd ./apache-configs/; sudo bash install.sh
    Create a .vhost file in /etc/frontview/apache/addons/
    cd /etc/frontview/apache/addons/; touch YOUR.DOMAIN.com.vhost
    The contents of YOUR.DOMAIN.com.vhost should be something like:
    <VirtualHost *:80>
    ServerName YOUR.DOMAIN.com
    DocumentRoot /YOUR_HTML_SHARE/a_sub_dir
    <Directory /YOUR_HTML_SHARE/a_sub_dir>
    AllowOverride All
    Order Allow,Deny
    Allow from all
    </Directory>
    SetHandler none
    Order Allow,Deny
    Allow from all
    </Location>
    SSLEngine off
    RewriteEngine On
    </VirtualHost>
    Restart Apache
  • Hi all,
    Very sorry im several years late with this one.
    Im a little new to this virtual hosting bu i wish to host more than one website on my Readynas Duo
    I can across a very usefull guide here on how to setup for multiple hosts with the virtual.conf file however, im unsure how to get to this file in order to modify it.
    I cant find it via windows explorer so i assume i must use ssl??? (which im also new too)
    Any tips on the best way to modify the conf file would be great.
    thanks in advance!
  • Hmmmm this guide work not on the Duo v1 2110
    I get a blank site :(
    I have try this guide many time now, and same result...
ProSupport for Business
