AndypigpenDoran
Nov 03, 2013Aspirant
How to increase max upload size for piwigo
I tried asking this question in the piwigo forums since it seems to be a common complaint that the max size for uploading files is 2 MB. There wasn't much help as soon as "ReadyNAS" was mentioned, the...
AndypigpenDoran
It would be even better to have a UI capability to set the upload size instead of having to use SSH to go in and find the file to modify. Whatever new default you set, someone will want "more"...
- Aug 18, 2018Retired_Member
