AndypigpenDoran
Nov 03, 2013Aspirant
How to increase max upload size for piwigo
I tried asking this question in the piwigo forums since it seems to be a common complaint that the max size for uploading files is 2 MB. There wasn't much help as soon as "ReadyNAS" was mentioned, the...
JohnNulty
Jan 03, 2014Apprentice
Many thanks S-P. I like the increase in photo size capability :wink: , but unfortunately synching still does appear to work. There are still no files in the ./galleries folder in piwigo, and I see no ./galleries folder in filezilla :cry:. Maybe there is no connection between piwigo and mysql? Do I really type in 'root' for the database box when setting piwigo up, or do I need to put in another local value? Just a thiught...
- Aug 18, 2018Retired_Member
