PeterBremer1
May 04, 2019Star
https for Piwigo and Prestashop, how to?
I have installed Piwigo and Prestashop
They run standard on http: ports, 7091 and 7541 respectively.
I have https: enabled on my RN424
How to convert these ports for https: access?
May 04, 2019Guru - Experienced User
I think you need to do this via the app configuration. For instance, https://www.siteground.com/kb/configure-prestashop-use-https/
PeterBremer1
May 04, 2019Star
No that does not work. If I try to activate SSL for Prestashop it just says SSL is not supported by the server
Idem for Piwigo: "Your hosting server does not support HTTPS,"
And I am sure the RN424 supports HTTPS as its own admin page works with its self-signed certificate. It is also enabled on the settings page.
So I think I just need to change something at the apache2 server of the RN424 for those ports, but do not know where, what and how
- Aug 18, 2018Anonymous
