Natedogg007
Nov 30, 2015Aspirant
Installing Php
Not sure if anyone can help with this! I purchased a readynas 202 running os6. I'm trying to create a web server. I've downloaded all the correct apps and it's working but I need to enable cURL! I ca...
mdgm-ntgr
Dec 01, 2015NETGEAR Employee Retired
Is the php5-curl package installed?
You could try installing it by doing e.g.
# apt-get install php5-curl
