benawhite1
Nov 28, 2007Aspirant
Installing PHP
Sorry for the newby question, but I am trying to install PHP4. I was able to get apt installed using this as a guide From that point I added the following line to /etc/apt/sources.list deb-src...
Plukkie
Jan 24, 2008Aspirant
btaroli wrote: Not as long as you *also* have the appropriate restrictions included in the /etc/apt/preferences file (like the latest version of the APT add-on provides).
Then you probably refer to the libc6 library, which indeed is blocked in the preferences file of apt?
