SJMarty
Aug 02, 2015Aspirant
iStat Installation on Sparc
I have an NV and an NV+ and I'm running NAS Utils on my Android phone. I'd like to install iStat to view performance but can't seem to find the installation steps. The app points to this URL but I ...
BrianL2
Aug 02, 2015NETGEAR Employee Retired
Hi SJMarty,
Can you check if this page opens up fine.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
SJMarty
Aug 04, 2015Aspirant
Yes, the link you provided I was able to open (although I didn't find any instructions on that page).
If you are able to open the page that I and others are having trouble with, would you mind just posting the installation instructions? Or, if you don't want to clutter the board, you could PM them to me. Either one would be much appreciated!
- StephenBAug 04, 2015Guru - Experienced User
There are no special installation instructions that I know of.
Just the usual
-open frontview
-select system->update from the left, then click on the local tab
-select the istat bin file with "choose file"
-then select "upload and verify"
-finally "perform system update".
Post install, you can see istatd in services->installed Add-ons.
You can set the numeric password, and also remove the add-on from there.
- SJMartyAug 11, 2015Aspirant
The file that I downloaded that I thought I was supposed to install was a .deb file. It was also much newer. I downloaded it from the author's (Poussin) Dropbox link he posted.
Is the .deb file not for the Sparc architecture?
- StephenBAug 12, 2015Guru - Experienced User
No, its not for the Sparc architecture. You need the bin. Maybe Poussin might update the bin (worth asking anyway).
