super_poussin's avatar
Oct 01, 2009
Istat
istat
  • Description:
    istatd is a daemon serving statistics to your iStat iPhone application from Linux, Solaris & FreeBSD. istatd collects data such as CPU, memory, network and disk usage and keeps the history. Once connecting from the iPhone and entering the lock code this data will be sent to the iPhone and shown in fancy graphs.
  • Requirements: RAIDiator 4.1.5+
  • Platform: sparc
  • Current Version: 1.5
    Istat (04/23/2010)
      • Changes in 1.5:
        • based on Istatd 0.5.7
        • Temperature and fan support with lm_sensors (not for Readynas)
        • Fix: Memory meterics incorrect in Linux (cached).
        • Fix: Do not create PID file if it's not specified in config.
        • Fix: Removed unneccesary linkage to libld.
        • Fix: Reverted load avg. probe for procfs.
        • Fix: Segfault when reading cache with more than one client.
        • Fix: PID file contained the mother PID when -d
        • now support bonjour (thanks chirpa)
      • Installation Notes:
        • require the istat iphone app link to appstore
          • you can change default password from frontview ui (by default 12345)
          • password must have a lenght of five digits
          • you can also edit /addons-config/istatd/istat.conf
          • Screenshots:
          • Old Versions:
            Istat (02/25/2010)
          • Credits:
            http://code.google.com/p/istatd/
    • Steffko's avatar
      Steffko
      Same with me !
      - maybe only available in the american store !?
    • StephenB's avatar
      Perhaps pm super_poussin.  The original post goes back to 2009, which is perhaps a hint that it is no longer in the store.
    • siigna's avatar
      siigna
      NETGEAR Employee Retired
      alfry82 wrote:
      sorry I do not find the application on the apple store
      Steffko wrote:
      Same with me !
      jonl0711 wrote:
      When will istat be available in Australian stores?
      The developer of iStat (bjango) says the iOS app is not currently available.
      iStat for iOS isn’t available right now — we’re working on a major update, and the older version doesn’t run well under iOS 9. We don’t have an ETA for its return, but it definitely will be back.
ProSupport for Business
