marcusp
May 13, 2015Tutor
Problem with Istat after several months
Hello,
I'm using my Readynas 102 just as a backup of my good old Readynas Pro 6, so the initial configuration has never changed, I'm just doing the OS updates from time to time.
Last time I noticed that NAS Utils (on android) didn't want to connect to Istat on the 102 but no problem with the Pro 6. In fact Istat didn't want to start anymore on the 102. I uninstalled it and try to reinstall it but it was not present in the apps. So I downloaded the .deb file and use it on the 102, the installation seemed to be ok but each time I want to start it, I've got this error:
is it a known problem with the lastest version of the OS ? I've not seen anything like this in the forum.
Thanks in advance if anybody has a solution :) !
- cpu8088Virtuosouninstall the app and then re-install?
- marcuspTutorAs I explained in my previous post I've already tried that, but it's not working...
- marcuspTutorI've made an OS reinstall but it didn't solver anything :? ...
here is a part of systemd-journal:Line 4715: Jun 07 11:32:01 ReadyNAS-102 apache_access[1519]: 192.168.1.10 "GET /apps/logo/istat.png HTTP/1.1" 200
Line 4717: Jun 07 11:32:04 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4718: Jun 07 11:32:04 ReadyNAS-102 istat[1760]: /apps/istat/bin/arm/istatd: no process found
Line 4719: Jun 07 11:32:04 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4720: Jun 07 11:32:04 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4721: Jun 07 11:32:05 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4722: Jun 07 11:32:05 ReadyNAS-102 istat[1777]: /apps/istat/bin/arm/istatd: no process found
Line 4723: Jun 07 11:32:05 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4724: Jun 07 11:32:06 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4727: Jun 07 11:32:07 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4728: Jun 07 11:32:07 ReadyNAS-102 istat[1795]: /apps/istat/bin/arm/istatd: no process found
Line 4729: Jun 07 11:32:07 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4730: Jun 07 11:32:07 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4731: Jun 07 11:32:08 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4732: Jun 07 11:32:08 ReadyNAS-102 istat[1811]: /apps/istat/bin/arm/istatd: no process found
Line 4733: Jun 07 11:32:08 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4734: Jun 07 11:32:08 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4735: Jun 07 11:32:09 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4736: Jun 07 11:32:09 ReadyNAS-102 istat[1829]: /apps/istat/bin/arm/istatd: no process found
Line 4737: Jun 07 11:32:09 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4738: Jun 07 11:32:09 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4739: Jun 07 11:32:10 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4740: Jun 07 11:32:10 ReadyNAS-102 istat[1847]: /apps/istat/bin/arm/istatd: no process found
Line 4741: Jun 07 11:32:10 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4742: Jun 07 11:32:11 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4743: Jun 07 11:32:11 ReadyNAS-102 systemd[1]: fvapp-istat.service start request repeated too quickly, refusing to start.
Line 4764: Jun 07 11:32:25 ReadyNAS-102 readynasd[1260]: Delete /apps/istat
Line 4772: Jun 07 11:32:27 ReadyNAS-102 readynasd[1260]: Application 'istat' is uninstalled successfully.
Line 4850: Jun 07 11:32:40 ReadyNAS-102 fv-app-install[2178]: [istat](0%) prepare
Line 4853: Jun 07 11:32:44 ReadyNAS-102 fv-app-install[2178]: apt-get install istat
Line 4857: Jun 07 11:32:46 ReadyNAS-102 readynasd[1260]: dpkg-query: package 'istat' is not installed and no information is available
Line 4860: Jun 07 11:32:46 ReadyNAS-102 fv-app-install[2178]: [istat](5%) download 1/1 dpkg -s istat 0/1151448
Line 4861: Jun 07 11:32:50 ReadyNAS-102 readynasd[1260]: Selecting previously unselected package istat.
Line 4863: Jun 07 11:32:50 ReadyNAS-102 readynasd[1260]: Unpacking istat (from .../istat-1.0.4-all.deb) ...
Line 4866: Jun 07 11:32:52 ReadyNAS-102 readynasd[1260]: Package: istat
Line 4875: Jun 07 11:32:52 ReadyNAS-102 readynasd[1260]: /etc/init.d/istat newconffile
Line 4878: Jun 07 11:32:52 ReadyNAS-102 fv-app-install[2178]: [istat](50%) install 1/1 dpkg -s istat
Line 4879: Jun 07 11:32:52 ReadyNAS-102 readynasd[1260]: Setting up istat (1.0.4) ...
Line 4894: Jun 07 11:32:58 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4895: Jun 07 11:32:58 ReadyNAS-102 istat[2420]: /apps/istat/bin/arm/istatd: no process found
Line 4896: Jun 07 11:32:58 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4897: Jun 07 11:32:58 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4898: Jun 07 11:32:59 ReadyNAS-102 fv-app-install[2178]: [istat](100%) complete
Line 4899: Jun 07 11:33:00 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4900: Jun 07 11:33:00 ReadyNAS-102 istat[2447]: /apps/istat/bin/arm/istatd: no process found
Line 4901: Jun 07 11:33:00 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4902: Jun 07 11:33:00 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4907: Jun 07 11:33:01 ReadyNAS-102 readynasd[1260]: Service 'fvapp-istat.service' goto unexpected state 'inactive'. Expect to be 'active'('activating').
Line 4908: Jun 07 11:33:01 ReadyNAS-102 readynasd[1260]: Application 'istat' is installed successfully.
Line 4919: Jun 07 11:33:04 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4920: Jun 07 11:33:04 ReadyNAS-102 istat[2582]: /apps/istat/bin/arm/istatd: no process found
Line 4921: Jun 07 11:33:05 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4922: Jun 07 11:33:05 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4923: Jun 07 11:33:06 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4924: Jun 07 11:33:06 ReadyNAS-102 istat[2602]: /apps/istat/bin/arm/istatd: no process found
Line 4925: Jun 07 11:33:06 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4928: Jun 07 11:33:06 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4929: Jun 07 11:33:07 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4930: Jun 07 11:33:07 ReadyNAS-102 istat[2618]: /apps/istat/bin/arm/istatd: no process found
Line 4931: Jun 07 11:33:07 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4932: Jun 07 11:33:07 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4933: Jun 07 11:33:08 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4934: Jun 07 11:33:08 ReadyNAS-102 istat[2634]: /apps/istat/bin/arm/istatd: no process found
Line 4935: Jun 07 11:33:08 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4936: Jun 07 11:33:09 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4937: Jun 07 11:33:10 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4938: Jun 07 11:33:10 ReadyNAS-102 istat[2652]: /apps/istat/bin/arm/istatd: no process found
Line 4939: Jun 07 11:33:10 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4940: Jun 07 11:33:10 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4943: Jun 07 11:33:11 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4944: Jun 07 11:33:11 ReadyNAS-102 istat[2668]: /apps/istat/bin/arm/istatd: no process found
Line 4945: Jun 07 11:33:11 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4946: Jun 07 11:33:11 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4947: Jun 07 11:33:11 ReadyNAS-102 systemd[1]: fvapp-istat.service start request repeated too quickly, refusing to start.
Line 4958: Jun 07 11:33:37 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4959: Jun 07 11:33:38 ReadyNAS-102 istat[2706]: /apps/istat/bin/arm/istatd: no process found
Line 4960: Jun 07 11:33:38 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4961: Jun 07 11:33:38 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4962: Jun 07 11:33:39 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4963: Jun 07 11:33:39 ReadyNAS-102 istat[2722]: /apps/istat/bin/arm/istatd: no process found
Line 4964: Jun 07 11:33:39 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4965: Jun 07 11:33:39 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4966: Jun 07 11:33:40 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4967: Jun 07 11:33:40 ReadyNAS-102 istat[2742]: /apps/istat/bin/arm/istatd: no process found
Line 4968: Jun 07 11:33:40 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4969: Jun 07 11:33:40 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4972: Jun 07 11:33:41 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4973: Jun 07 11:33:41 ReadyNAS-102 istat[2758]: /apps/istat/bin/arm/istatd: no process found
Line 4974: Jun 07 11:33:41 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4975: Jun 07 11:33:41 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4976: Jun 07 11:33:42 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4977: Jun 07 11:33:42 ReadyNAS-102 istat[2776]: /apps/istat/bin/arm/istatd: no process found
Line 4978: Jun 07 11:33:42 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4979: Jun 07 11:33:43 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4980: Jun 07 11:33:44 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4981: Jun 07 11:33:44 ReadyNAS-102 istat[2794]: /apps/istat/bin/arm/istatd: no process found
Line 4982: Jun 07 11:33:44 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4983: Jun 07 11:33:44 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4984: Jun 07 11:33:44 ReadyNAS-102 systemd[1]: fvapp-istat.service start request repeated too quickly, refusing to start.
Do you have any solution ? - mdgm-ntgrNETGEAR Employee RetiredAny other apps installed?
- marcuspTutorJust SMB plus & Phpsysinfo. I've tried to keep this NAS as clean as possible since that's just the backup of the big one...
- mdgm-ntgrNETGEAR Employee RetiredCan you send me your logs (see the Sending Logs link in my sig)?
- marcuspTutorI've just sent them to you
