Chris47111
May 05, 2018Aspirant
Length of Scrub Maintenance
Hi Folks,
I know that question was asked at least one time before. But I did not find a suitable answer for that.
I started scrubbing my HDDs on May1st. Now, May 5th 51% are done. Thus itll be do...
- May 12, 2018
It could be related to the quota, so if you can live without that try disabling it.
You can also clear the quota on the volume, not just the share. That will reduce the space information you see on the share page in the web ui.
The log you're looking at just reports the higher-level summary on the scrub - it doesn't show the two steps separately. I've never needed to see those details, so I don't know where they'd be logged. You could look in system.log and kernel.log.
Chris47111
Hi bedlam1,
I have 2x4TB WD RED installed.
Status is "healthy" , Firmware 6.9.3, XRaid enabled, AV Service enabled, BitRot and Autodefrag disabled
and 2.6 TB free.
thx,
Chris
May 06, 2018Guru - Experienced User
If the performance is adequate then I suggest letting it run to completion.
A scrub takes about 40 hours on my RN526 with 4x6TB. It scales with raw disk size, so I'd estimate about 13 hours for 2x4TB. An RN100 series will of course be slower, but 10 days sounds high.
Did you download the log zip file, and look at the SMART stats? You can see them in volume.log.
- Chris47111May 06, 2018Aspirant
Hi StephenB,
" If the performance is adequate then I suggest letting it run to completion." I think, that's what I'll do.
"but 10 days sounds high." I agree. And I'd like to know, why it takes so long.
"Did you download the log zip file, and look at the SMART stats? You can see them in volume.log." Not yet. Are you talking about the attatched logfile you can access System--> logs ? Or do I have to access ReadyNas via SSH for that?
Maybe I just have a "stupid configuration" ;-)
Thanks,
Chris
- bedlam1May 06, 2018Prodigy
It is in the System/Logs zip file you can download using the GUI or Raidar
- StephenBMay 06, 2018Guru - Experienced User
Correct - There's a download link on the same page you clipped for your log png.
BTW, it's best to run the maintenance functions one at a time (instead of starting a defrag a few seconds after the you started the scrub).
