Chris47111
May 05, 2018Aspirant
Length of Scrub Maintenance
Hi Folks,
I know that question was asked at least one time before. But I did not find a suitable answer for that.
I started scrubbing my HDDs on May1st. Now, May 5th 51% are done. Thus itll be do...
- May 12, 2018
It could be related to the quota, so if you can live without that try disabling it.
You can also clear the quota on the volume, not just the share. That will reduce the space information you see on the share page in the web ui.
The log you're looking at just reports the higher-level summary on the scrub - it doesn't show the two steps separately. I've never needed to see those details, so I don't know where they'd be logged. You could look in system.log and kernel.log.
bedlam1
May 06, 2018Prodigy
It is in the System/Logs zip file you can download using the GUI or Raidar
May 06, 2018Guru - Experienced User
Correct - There's a download link on the same page you clipped for your log png.
BTW, it's best to run the maintenance functions one at a time (instead of starting a defrag a few seconds after the you started the scrub).
- Chris47111May 11, 2018Aspirant
Hi bedlam1,
I reorganised all the task to one tast per month, starting on January 1st, Feb. First etc.
Nonethelesss I'd like to know, why the scrub took so long. Ok, while scrupping the ReadyNas was in use, what might have caused that slowdown.
I'd like an option like "run on every first saturday on January etc. This way such a task has "all the time needed" to complete without the dayly work...
- StephenBMay 11, 2018Guru - Experienced User
How long did it actually take?
The scrub actually finished on May 9th,9:23pm.Starting on 1st of May midnight, it took nine days and 21 hours....
