nhelp
Aug 22, 2015Aspirant
Management Service is offline - Due to Plex
I have a RN104 and use it primarily as a streaming media server. Any attempts to use plex (installed on the RN) results in the systems management service going offline in addition to the front interf...
Aug 22, 2015Guru - Experienced User
I have seen the web ui become unresponsive for a bit when plex was building or updating a library. Not sure, but I suspect that's a task prioritization issue.
But I haven't seen the web ui become unresponsive simply because I was using plex. Only when I was creating or updating a large library.
Are you seeing something different?
nhelp
Yes, the issue is not associated to the plex library update; even after the library update the detailed issues persist and are only temporarily resolved via a restart (using RaidAr).
- StephenBAug 23, 2015Guru - Experienced User
You tried uninstalling/reinstalling plex?
Also are you using the normal 32400 port for the plex interface?
- vandermerweAug 23, 2015Master
Have you tried mdgm's suggestion to turn off as many services as you can and seeing if the problem goes away?
- nhelpAug 23, 2015Aspirant
Yes, I have tried shutting down services. DLNA, and Antivirus were recently shut down to test. The problem still remains. I have also accomplished the uninstall and reinstall of plex (even used different versions) - The problem remains that if you use Plex with my RN, those issues occur. I appreciate all of the feedback/assistance.
- mdgm-ntgrAug 23, 2015NETGEAR Employee Retired
Which version of Plex are you running?
- Jun 10, 2022Retired_Member
