nhelp
Aug 22, 2015Aspirant
Management Service is offline - Due to Plex
I have a RN104 and use it primarily as a streaming media server. Any attempts to use plex (installed on the RN) results in the systems management service going offline in addition to the front interf...
nhelp
Yes, the issue is not associated to the plex library update; even after the library update the detailed issues persist and are only temporarily resolved via a restart (using RaidAr).
Aug 23, 2015Guru - Experienced User
You tried uninstalling/reinstalling plex?
Also are you using the normal 32400 port for the plex interface?
- vandermerweAug 23, 2015Master
Have you tried mdgm's suggestion to turn off as many services as you can and seeing if the problem goes away?
- nhelpAug 23, 2015Aspirant
Yes, I have tried shutting down services. DLNA, and Antivirus were recently shut down to test. The problem still remains. I have also accomplished the uninstall and reinstall of plex (even used different versions) - The problem remains that if you use Plex with my RN, those issues occur. I appreciate all of the feedback/assistance.
- mdgm-ntgrAug 23, 2015NETGEAR Employee Retired
Which version of Plex are you running?
- StephenBAug 23, 2015Guru - Experienced User
Also I am wondering if the issue is specific to some of your media files - that is not uncommon with streaming media servers.
Did you try starting with a small library of files that are known to be good and are properly tagged?
- Jun 10, 2022Retired_Member
