hamvil
Jan 20, 2012Aspirant
MediaTomb for ReadyNAS Ultra
Hi, I've finally managed to run MediaTomb on my ReadyNAS Ultra 4. With the current setup I can stream any video to my PS3. Subtitles are supported but only as external srt or sub file (that must be...
yupsolo
Jan 24, 2012Aspirant
here's:
nas-8B-2D-9C:~# apt-get install libfreetype6 ttf-dejavu ffmpeg lsdvd
Reading package lists... Done
Building dependency tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
ffmpeg: Depends: libavcodec0d (>= 0.cvs20060823) but it is not going to be installed
Depends: libavformat0d (>= 0.cvs20060823) but it is not going to be installed
Depends: libsdl1.2debian (>= 1.2.10-1) but it is not going to be installed
libsigc++-2.0-dev: Depends: pkg-config but it is not going to be installed
Depends: libstdc++-dev
squeezeboxserver: Depends: sox but it is not going to be installed
Depends: libvorbisenc2 but it is not going to be installed
Depends: libvorbisfile3 but it is not going to be installed
ttf-dejavu: Depends: defoma but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
