anonynas
Mar 06, 2011Aspirant
Mercurial (hg) SCM on ReadyNAS?
Hi All, I was wondering if anyone has successfully installed Mercurial on their ReadyNAS. I'm struggling because I can't seem to get a complete Python install. I downloaded and installed Python ...
anonynas
Mar 16, 2011Aspirant
WhoCares? wrote: You could try apt-get install bz2if you've got the APT add-on installed. Other than that all I can say is that I'm working on it but want to use Python 2.6 instead of 2.5. Unfortunately this still gives me some headaches, otherwise the Mercurial add-on would be available already.
-Stefan
Hi Stefan,
Yeah, I did apt-get install bz2, which is why I'm so confused. I also downloaded the package descriptions for the sparc release of Sarge and installed everything that seemed relevant when I grepped for bz2, but to no avail. I don't know if it is a path issue or something?
I didn't try Python 2.6, but I did try 2.7, and it came up with far more complaints than 2.5 did. I'm really confused why this is so hard; it should be trivial.
Cheers!
