russallred
Mar 17, 2018Aspirant
Milestone Arcus license key expired
Hello, I am trying to enter my license key at https://milestone.netgear.com/activate and I get an error code which says License Key is expired. I copied and pasted from the e-mail from the 3rd p...
- Mar 22, 2018
Hi @russalred
Can you please try to activate the license again, it should work okay now.
Regards
Marc_V
Mar 18, 2018NETGEAR Employee Retired
Hi russallred
Welcome to the Community!
Where did you bought the license? How many cameras are included? Licenses should be good for 5 years, If it is the trial license that came with the NAS then it will be good only for 60 days and then you have to purchase a regular license which are sold for 1, 4 or 8 cameras. You should have purchase the license from an authorize distributor/reseller.
Just to check have you tried using a different browser or asking for a different license key? This is to test if there are any issues with the activation.
I copied and pasted from the e-mail from the 3rd party seller and selected the serial number.
This would be the best step for now, send an email to your reseller or better return the purchased license. You should be able to ask for a replacement key.
Regards
russallred
Mar 18, 2018Aspirant
Hello Marc and thank you for replying.
I bought RNVMSMA4-10000S (For Milestone 4 channel) from Netgear4Less.com . I tried to activate originally using the chrome browser, but I get the same result using IE. I sent an e-mail to the seller.
We'll see. Thank you.
- Marc_VMar 19, 2018NETGEAR Employee Retired
Hi russallred
Can you also PM me the license key and also a screenshot of the error message.
Regards
- Marc_VMar 22, 2018NETGEAR Employee Retired
Hi @russalred
Regards
- try2helpMar 22, 2018Aspirant
We found an issue in the backend, the fix is to be deployed tonight Pacific time, please try to activate again tomorrow morning. Thank you!
