russallred
Mar 17, 2018Aspirant
Milestone Arcus license key expired
Hello, I am trying to enter my license key at https://milestone.netgear.com/activate and I get an error code which says License Key is expired. I copied and pasted from the e-mail from the 3rd p...
- Mar 22, 2018
Hi @russalred
Can you please try to activate the license again, it should work okay now.
Regards
russallred
Mar 18, 2018Aspirant
Hello Marc and thank you for replying.
I bought RNVMSMA4-10000S (For Milestone 4 channel) from Netgear4Less.com . I tried to activate originally using the chrome browser, but I get the same result using IE. I sent an e-mail to the seller.
We'll see. Thank you.
Marc_V
Mar 19, 2018NETGEAR Employee Retired
Hi russallred
Can you also PM me the license key and also a screenshot of the error message.
Regards
- Marc_VMar 22, 2018NETGEAR Employee Retired
Hi @russalred
Regards
- try2helpMar 22, 2018Aspirant
We found an issue in the backend, the fix is to be deployed tonight Pacific time, please try to activate again tomorrow morning. Thank you!
- russallredMar 23, 2018Aspirant
Hello and thank you for looking into this. I am getting a different error at this time.
