Bats586
Feb 10, 2016Aspirant
Minimserver on RN104?
Hi,
Has anyone managed to get minimserver running on a readynasRN104? I think it will require a manual install as it won't install as a plugin/app (downloaded form the minimserver site) from the admin page on the device - says only "deb" packages are supported.
If so any chance you could share an "idiots" guide to installing please?
Thanks in advance
1 Reply
- JennCNETGEAR Employee Retired
Hello Bats586,
http://apps.readynas.com/pages/?page_id=9 is the link where you can get all registered ReadyNAS OS6 apps. It seems Minimserver is not registered yet, it may also help if you check this with Minimserver app developer.
