super_poussin
Jun 14, 2013Virtuoso
Missing addons
Hello Guy, In your opinion what is the best addon , which is missing on Readynas R6 ?
arnomc
Oct 07, 2013Aspirant
super-poussin wrote: you should see a ddclient under free apps on frontview
super-poussin wrote: DDClient addon in the dropbox
Thanks a lot super-poussin ! Me and my RN6 are finally back where I have a IP dynamically assigned by my ISP. So I happily tried your new addon but it doesn't went so well :'(
First, I tried both method of installation (it's not the main problem) :
- if I download the addon from your dropbox then installing it by browsing from frontview => it says "failed to install add-on" even if I see the icon under 'installed apps'.
- however, when I install the addon directly in frontview from the list of 'available apps' then it will say "installed sucessfully".
But the real problem is when I try to copy the config file. Then I have this error (sorry it's in french, so it says : "Impossible to finish the operation because an unexpected error occurred (error code -8058)"
I don't think the 'bug' of my first installation (through dropbox) could case this error. I didn't find anything on google about error code -8058. So I am forced to ask all of you in the forum if anyone could help me to edit that ddclient.conf file.
