super_poussin
Jun 14, 2013Virtuoso
Missing addons
Hello Guy, In your opinion what is the best addon , which is missing on Readynas R6 ?
xeltros
Feb 13, 2014Apprentice
libio-socket-ssl-perl must be installed
I would say install libio-socket-ssl-perl ;)
I don't know which tool you use to install packages but stick with that one.
apt-get install libio-socket-ssl-perl should work
aptitude install libio-socket-ssl-perl if you used aptitude before
you may want to do apt-get update or aptitude update before to refresh the packages lists.
