super_poussin
Jun 14, 2013Virtuoso
Missing addons
Hello Guy, In your opinion what is the best addon , which is missing on Readynas R6 ?
Lichon
Apr 13, 2014Aspirant
Maybe I am missing something obvious, but app listing say Transmission v3.00.3 yet the about window inside transmission says v2.82 (14160). Isnt that an error ?
Any chance this edition of Transmission can create torrent files?
There was a create button on OS4 addon, but it never worked for me.
When I want to change the paths for transmission, do I need to edit the /data/.apps/transmissionr6/bin/start.sh script or is there an XML/TXT/INI config somewhere?
I see some hardcoded paths there. Still havent found an existing setting for the old "sources" folder, where you could dump ".torrent" files to aka watch folder.
