super_poussin
Jun 14, 2013Virtuoso
Missing addons
Hello Guy, In your opinion what is the best addon , which is missing on Readynas R6 ?
mmajoor
Apr 20, 2014Aspirant
I would love to see latest versions of NZBGet (http://nzbget.sourceforge.net/Main_Page) & sabnzbd (http://sabnzbd.org).
Cheers
dbsx
Like dbsx I was hoping to use a more recent version of NZBGet to get a complete replacement of SABnzbd (including RSS feeds).
I decided to try compiling NZBGet myself. After some struggles using the virtual machine and SDK (the struggles -not- related to the SDK mind you), I decided a different approach and started using my host system directly and only using the cross compiler from the SDK.
Having the same struggles initially as with the virtual machine and SDK, I finally managed to get the NZBGet app compiled.
Important note: The 'direct' compile approach, using the host system directy, does not use any 'failsafes' like chroot etc, so errors made can have an effect on the main system in some circumstances. You should be aware of that.
The result of these can be found on my site:
http://www.majority.nl/projects_miscellaneous.htm
You will find two downloads there. One contains only the app packages. I have included two versions: V12.0 which is a stable version and V13.0 which is based on a testing version. I had some issues using V13.0 myself, so I can't recommend it at this stage (but you decide for yourself).
The second download contains the complete sources and scripts I used to compile those packages. Everything is included. The only additional requirements are the 'basic' compiling tools that must be present on your host system.
I should also note that the the packages are for arm based devices only, so for the RN10x.
