super_poussin
Jun 14, 2013Virtuoso
Missing addons
Hello Guy,
In your opinion what is the best addon , which is missing on Readynas R6 ?
- robotslaveAspirantI have been trying that URL all evening. It times out every time.
- mdgm-ntgrNETGEAR Employee RetiredThere are some changes coming: http://www.readynas.com/forum/viewtopic.php?p=405548#p405548
So maybe we will hear more when the next firmware is released.
You can develop apps for x86_64 even if you don't have a physical unit by running the VM (see http://www.readynas.com/forum/viewtopic.php?f=35&t=70699) in VirtualBox on your PC/Mac. Since you have an ARM unit you could make addons that run on both ARM and x86_64 - robotslaveAspirantThanks for the tip, but what I really want is the server end of a client/server backup solution, running on R6/ARM. Obviously porting software like that to R6/amd64 won't quite get me there.
Are you saying the SDK for x86_64 includes cross-compiling for ARM?
Do you know if the developer network ( https://developer.netgear.com/home ) is simply experiencing technical problems, or has it been taken offline? - Backdraft090782Aspiranthi all
iam still searching the whole day for a addon for downloading from oneclickhosters. There are much questions on the forum so i think there is a market for and iam not the only one - hopefully :)
Pyload on my R4 (i have two nas) is nice but i cant get him to download on R6 because python 2.7 isnt out. (error: DLC_27)
there are several addons like mldonkey (isnt the best opinion because its in 1 position for torrents) or rapidleech. But iam a beginner and dont have much skill in linux or python or something else :)
So, there are a few addons i am missing: Python 2.7 and mldonkey or rapidleech (or something else..)
yours Backdraft - Hi, I previously used the dropbox add-in under 4.x but is it available under 6.x?
i know that dropbox is available via frontview in 6.x but i previously used the 4.x dropbox add-in to copy auto-upload photos sent from my smartphone to dropbox to my readynas - i don't think we can do this under the 6.x dropbox?
many thanks
Steve - super_poussinVirtuosoyour right dropbox only contain addons for OS 6
- strung3GuideHi
An emule client addon is missing on the readynas client OS 6.
Regards, - dsnpevlVirtuosoHi forum,
I could really use an add-on that switches on Server Side Includes (SSI) on ReadyNAS (516).
See also https://www.readynas.com/forum/viewtopic.php?f=7&t=72854 and https://www.readynas.com/forum/viewtopic.php?f=36&t=73204
Best regards,
dsnpevl. - arnomcAspirant
super-poussin wrote: you should see a ddclient under free apps on frontview super-poussin wrote: DDClient addon in the dropbox
Thanks a lot super-poussin ! Me and my RN6 are finally back where I have a IP dynamically assigned by my ISP. So I happily tried your new addon but it doesn't went so well :'(
First, I tried both method of installation (it's not the main problem) :
- if I download the addon from your dropbox then installing it by browsing from frontview => it says "failed to install add-on" even if I see the icon under 'installed apps'.
- however, when I install the addon directly in frontview from the list of 'available apps' then it will say "installed sucessfully".
But the real problem is when I try to copy the config file. Then I have this error (sorry it's in french, so it says : "Impossible to finish the operation because an unexpected error occurred (error code -8058)"
I don't think the 'bug' of my first installation (through dropbox) could case this error. I didn't find anything on google about error code -8058. So I am forced to ask all of you in the forum if anyone could help me to edit that ddclient.conf file. - arnomcAspirantAddendum from Super-poussin (while i was preparing my last post) :
super-poussin wrote: Try to reset the rights on the share using the dashboard , it should solve the issue
=> Thanks I am trying this right now, and will keep you posted.
EDIT : I was making a mistake preventing me to log in as an 'admin' like I thought I was.
So the DDclient addon is working perfectly as intendend !
Thanks super-poussin :)
