cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
cpitchford
Jun 05, 2009Guide
chirpa wrote: No C2Q support on that Q965 chipset. :( http://www.microcenter.com/single_produ ... id=0309580
BLIMEY you'd be lucky.. The heatsink just is NOT up to that task :) but you're right.. the chipset doesn't seem to support anything later than the E6x00 series.. It doesn't support E6x50 chips either.. which is a shame.. the newer chips might not be any faster, but they DO run cooler..
Also, at idle, the E6600 runs at 31 degress C (temp2) which is very happy and healthy!
