cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
cpitchford
Jun 05, 2009Guide
ha.. asides from the tiny heatsink glowing white hot, the Q963/965 chipset that (I think) is on the Pro mobo doesn't support the Q6xxx chips.. Have a look at ark.intel.com:
http://ark.intel.com/Product.aspx?id=29765
It lists the G965 and P965, but not the Q965. Does anyone actually know which intel chipset is used on the Pro?
Was looking at the ThermalTake MeOrb heatsink.. it is 47mm high :) That E6700 might yet work
