cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
cpitchford
Jun 06, 2009Guide
http://ixbtlabs.com/articles2/mainboard ... ipset.html
" By the way, i965 chipsets do not officially support quad-core processors (Kentsfield core). "
Officially? So, it could be a BIOS issue to coax it into working.. The mobo has a VGA header 2x8 pins. I had VGA header cable from a n old PCI graphics card, but I binned it only a few months ago.. chucking out old parts claiming I'd never need them again.. always the way... but I figure attaching a screen might be one way of actually figuring out exactly what chipset and what BIOS date the system is using..
The q963 chipset almost certainly won't support a quad core, but a modern q965 might.. Venting 95watts is a serious problem, though.. internal water cooling might be an option, the disk bay fan at the back is pretty large.. but I wouldn't want to risk disks overheating.. And dremmling a hole in the side of the case is just a pity
