cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
BrakinDeep
Sep 02, 2009Aspirant
cpitchford wrote: Was looking at the ThermalTake MeOrb heatsink.. it is 47mm high :) That E6700 might yet work
Just curious, did you ever try the MeOrb?
Did it work for you?
