cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
chal2les
Dec 19, 2009Aspirant
I have a k45 and it supports E6600/E6700, but does not support 1333 fsb . Even though this was the case. I was able to put in a E8400, and it would boot up(had to skip the warning that it was running at a lower freq(I disable check in the bios and it booted perfectly).
The end result that the CPU ran alot cooler and at the same speed.
Anyone tried 1333 fsb yet?
