cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
MikeMcr1
Feb 06, 2010Aspirant
Hmm, I notice Intel has confused matters by replacing the E6600 with another E6600 that runs at 3.06 GHz! It uses a smaller die size of 45 nm.
http://ark.intel.com/Compare.aspx?ids=42807,27250,
Since it shares the same name, would you expect it to be as compatible as the "old" 2.40 GHz E6600?
