cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
super_poussin
Mar 06, 2010Virtuoso
changing the cpu
jedi:~# iperf -c 192.168.101.21 -P4
Client connecting to 192.168.101.21, TCP port 5001
TCP window size: 73.0 KByte (default)
[ 6] local 192.168.101.50 port 43391 connected with 192.168.101.21 port 5001
[ 3] local 192.168.101.50 port 43388 connected with 192.168.101.21 port 5001
[ 4] local 192.168.101.50 port 43389 connected with 192.168.101.21 port 5001
[ 5] local 192.168.101.50 port 43390 connected with 192.168.101.21 port 5001
[ 5] 0.0-10.0 sec 476 MBytes 398 Mbits/sec
[ 4] 0.0-10.1 sec 52.3 MBytes 43.5 Mbits/sec
[ 6] 0.0-10.1 sec 454 MBytes 377 Mbits/sec
[ 3] 0.0-10.3 sec 251 MBytes 205 Mbits/sec
[SUM] 0.0-10.3 sec 1.20 GBytes 1.01 Gbits/sec
Skywalker:~# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 7370 MB in 2.00 seconds = 3690.37 MB/sec
Timing buffered disk reads: 710 MB in 3.00 seconds = 236.50 MB/sec
Skywalker:~#
Skywalker:~# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
stepping : 6
cpu MHz : 2394.000
cache size : 4096 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflus h dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_g ood pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm lahf_lm tpr_shadow
bogomips : 4788.16
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 15
stepping : 6
cpu MHz : 2394.000
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
bogomips : 8616.90
clflush size : 64
power management:
