cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
mrwizardno2
Mar 14, 2010Guide
So I decided to upgrade my ReadyNAS Pro's CPU tonight and when I went to loosen the CPU heatsink, one of the screws snapped off in the mount. The mounts look permanent. Thoughts on how I can rectify this problem? I checked out those screw grabbers at Lowes, but they're huge and meant for large screws. The screw looks to have loc-tite or something similar around it! I thought that was strange. Anyway...
So, am I "screwed?"
So, am I "screwed?"
