cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
chirpa
Mar 15, 2010Luminary
Can you take a picture of it?
mrwizardno2 wrote: So I decided to upgrade my ReadyNAS Pro's CPU tonight and when I went to loosen the CPU heatsink, one of the screws snapped off in the mount.
Best I can do to help you, is get you a replacement heatsink, if that is all thats broken. I replaced a CPU the other day in a Pro, so I have a spare heatsink by lucky chance.
