cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
chirpa
Mar 24, 2010Luminary
Hook up a USB keyboard, press DEL on bootup to get into the BIOS. Check under Boot for the boot order.
Yes, the internal Flash is behind the LED screen.
