cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
MrCyberdude
Jun 20, 2010Guide
@cpitchford. Hi, I was wondering which version of CPU you had for EACH of the E6600 and E6700 as I cannot find mention of it in your post. ?
SL9S7, SL9ZF, SL9ZL, SL9S8. Any Alternatives for both CPU and Fan?
E6700 http://processorfinder.intel.com/details.aspx?sSpec=SL9S7
These parts have Extended Halt (C1E) power of 22W.
These parts have THERMTRIP# enabled
E6700 http://processorfinder.intel.com/details.aspx?sSpec=SL9ZF
These parts have Extended Halt (C1E) power of 12W.
These parts support Thermal Monitor 2 (TM2) feature
They have quite different C1E values that may possibly make the difference. Also there is TM2?
I'm not so concerned about the N^ speed but would like some CPU choices as they are almost extinct.
http://www.hardwaresecrets.com/article/ ... odes/611/1
Also your E6600 comes in 2 variants
E6600 http://processorfinder.intel.com/details.aspx?sSpec=SL9ZL
Missing: These parts have THERMTRIP# enabled --**-- This is on Intels Site.. Typo maybe ??
E6600 http://processorfinder.intel.com/details.aspx?sSpec=SL9S8
