cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
WhoCares_
Sep 15, 2010Mentor
jakkes wrote: Did you find a cpu that did work?
Core2 E6600 & E6700 (why Intel did re-use these numbers for the Dual-Core Pentium, I'll never understand).
On Intel's site, look up the DP965/967 Chipset specs. There should be a list of compatible CPUs (at least there was last time I looked).
-Stefan
