cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
ddoming73
Nov 10, 2010Tutor
Just installed a Core 2 Duo E6700 with a Silverstone FM83 fan on Readynas Pro Pioneer
http://www.silverstonetek.com/products/p_contents.php?pno=fm83
Some slight tinkering is necessary to make the fan fit as it is so tall that it touches the side panel, but everything seems to be running fine. I do hope the increased power of the fan (it is actually a 92mm fan in a 80mm frame, with up to 72 CFM) offsets the increase in power of the CPU.
I have a question:
Is it possible to control the minimum/maximum fan RPM in the Pro? I have seen an add-on for this but it is only for Sparc.
I have a question:
