cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
xtrips1
Aug 01, 2011Aspirant
Thanks for sharing.
So to sum up, I can go for a E6700 and 4Gb of ram without worries.
I still have some more questions though.
Is that compatible with my Readynas Pro (not Pioneer)?
I suppose the 4Gb ram are 2x2Gb DDR2, but what kind? I mean the laptop kind or PC kind? What speed?
Is the access ti the mobo easy? Maybe screenshots or a Youtube howto is available?
Thx
Thx
