cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
ddoming73
Aug 01, 2011Tutor
hi
The Pro and Pro Pioneer are the same hardware. So it should work fine on the Pro.
Regarding the memory, it is normal PC DDR2 memory, I don't remember the exact speed rating I bought, but there are some threads on compatible memory here at the forums. A lot of people have successfully upgraded, so it should not be a problem.
Regarding the CPU, getting ahold of one will be tough, I had to buy mine on ebay... Nothing special about installing it, except that I recommend you clean out the stock thermal paste throughly and spend a few bucks on artic silver. You'll get a few degrees better cooling just for that.
Sorry no videos...
Sorry no videos...
