cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
MikeMcr1
Aug 02, 2011Aspirant
xtrips wrote: Isn't there any vga output on the mobo? Something that could give me a hint?
Yes, there is a VGA header if I remember correctly. You need a "Low Profile Graphics Card Bracket VGA Extension Cable" to use it.
