cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
ddoming73
Aug 04, 2011Tutor
Hi,
Regarding the CPU, I'm pretty sure it is NOT going to work. The E6700 part that works with the Readynas is rated to 2.66 GHz.
http://ark.intel.com/products/27251/Intel-Core2-Duo-Processor-E6700-(4M-Cache-2_66-GHz-1066-MHz-FSB)
And it is NOT easy to find as I think it is no longer being manufactured.
Regarding the memory, I read a bit in the forum before buying... I have looked at my mails and found the invoice. This is what I bought, and it work inmediately with no tinkering.
http://www.crucial.com/uk/store/partspecs.aspx?IMODULE=BL2KIT25664AA80A
Hope this helps...
Hope this helps...
