cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
sleepy06405
May 22, 2012Aspirant
I have a qx6700 here I could try. Its the same as the q but has an unlocked multiplier. The Q chips put out twice the heat though, there is no space in the readynas for an appropriate heatsink. I've had random luck with the qx, not everything that accepts the q will take the qx, which is silly, its the same exact chip, just unlocked. I'll give it a try and see if it boots.
