cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Korky
Jun 12, 2012Aspirant
sleepy06405 wrote: For lack of a better word........ Holy crap!
NAS:~# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 Quad CPU @ 2.66GHz
stepping : 7
cpu MHz : 2394.203
cache size : 4096 KB
Intel Core2 Extreme CPU QX6700 2.66/8M/1066 SL9UL
A q6700 should work fine. There are going to be cooling issues but yes, it boots.
Its running about 30% hotter than the core2quad but the fan is maxing out accomplishing that. I'm nuts and I won't run this chip.
There's got to be a heat-sink and fan out there up for the challenge of bringing down the temp on the q6700. Having the q6700 working without the temp issue would be perfect!! I am already on the case and will be posting back a reply if i get anywhere with this- otherwise its the E6700 for me :( Has anyone else got any experience with cooling cpu's - more a question for the hard-core overclocker out there i think.
