cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
grimloch
Jun 12, 2012Aspirant
cpitchford wrote:
Now, the temp1 is still higher than the "max" value.. I still don't know if that is a problem.. however. temp2 on frontview reports a MUCH healthier 53 degrees C
So.. the E6600 is 8 degrees cooler running flat out.. and is below the 60 degree limit.. both CPU cores report higher than max levels.. but both are lower than the "crit" level.. so I'm still working out (reading the source and CPU spec) what this means.
Slight pain is that the CPU cooler is attached with screws.. the backing plate is part of the case so heatsinks that screw on can be used.. Stock intel coolers, for example, with their push plugs cannot be used in this case.
If only the case was 1 CM wider a MUCH nicer fan could be put in..but from what I can tell, the tallest cooler you could use is 53mm and the selection is limited..
From what I can tell, the NAS is happy and relatively cool running an E6600, but an E6700 is going to be pushing it.. I've not tried a kernel compile reliability test or a memtest on the E6700 but I don't honestly think the CPU cooler is up to it..
If I can get a larger cooler, that uses screws rather than push plugs, I might try again.. but in the mean time 2.4Gig seems that safe limit with the stock readynas cooler.. (which is remarkably small compared to the intel stock ones! like less than half the height!)
Shame.. Still 2.4G is pretty damn good! :)
If I find out what the temp1_max actually means (ie can it be safely exceeded / temp1_crit is the REAL top limit) I'll let you all know
Sounds like we're working with 53mm max height for the heatsink (without modification), which is pretty limiting.
Sent from my MB855 using Tapatalk 2
