cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Korky
Jun 21, 2012Aspirant
So the best CPU now stands as the Q6700 Quad
Here is the frontpanel view running Plex transcoding MKV files to two different clients at 1080p, as well as copying 312 GB of data from NAS Ultra to my PC at the same time (figures below taken after 4 hours of heavy use) :
Fan SYS 1339 RPM OK
Fan CPU 2163 RPM OK
Temp SYS 57 C / 134 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 33 C / 91 F [Normal 0-85 C / 32-185 F] OK
/sys/devices/platform/coretemp.0/temp1_max:82000
/sys/devices/platform/coretemp.0/temp1_label:Core 0
/sys/devices/platform/coretemp.0/temp1_crit_alarm:0
/sys/devices/platform/coretemp.0/temp1_input:43000
/sys/devices/platform/coretemp.0/temp1_crit:100000
/sys/devices/platform/coretemp.1/temp1_max:82000
/sys/devices/platform/coretemp.1/temp1_label:Core 1
/sys/devices/platform/coretemp.1/temp1_crit_alarm:0
/sys/devices/platform/coretemp.1/temp1_input:43000
/sys/devices/platform/coretemp.1/temp1_crit:100000
/sys/devices/platform/coretemp.2/temp1_max:82000
/sys/devices/platform/coretemp.2/temp1_label:Core 2
/sys/devices/platform/coretemp.2/temp1_crit_alarm:0
/sys/devices/platform/coretemp.2/temp1_input:42000
/sys/devices/platform/coretemp.2/temp1_crit:100000
/sys/devices/platform/coretemp.3/temp1_max:82000
/sys/devices/platform/coretemp.3/temp1_label:Core 3
/sys/devices/platform/coretemp.3/temp1_crit_alarm:0
/sys/devices/platform/coretemp.3/temp1_input:45000
/sys/devices/platform/coretemp.3/temp1_crit:100000
/sys/devices/platform/w83627ehf.2576/temp1_input:58000
/sys/devices/platform/w83627ehf.2576/temp1_max:127000
/sys/devices/platform/w83627ehf.2576/temp1_max_hyst:125000
/sys/devices/platform/w83627ehf.2576/temp1_alarm:0
/sys/devices/platform/w83627ehf.2576/temp1_type:4
/sys/devices/platform/w83627ehf.2576/temp2_input:33500
/sys/devices/platform/w83627ehf.2576/temp2_max:80000
/sys/devices/platform/w83627ehf.2576/temp2_max_hyst:123000
/sys/devices/platform/w83627ehf.2576/temp2_alarm:0
/sys/devices/platform/w83627ehf.2576/temp2_type:1
/sys/devices/platform/w83627ehf.2576/temp3_input:2000
/sys/devices/platform/w83627ehf.2576/temp3_max:80000
/sys/devices/platform/w83627ehf.2576/temp3_max_hyst:123000
/sys/devices/platform/w83627ehf.2576/temp3_alarm:0
/sys/devices/platform/w83627ehf.2576/temp3_type:4
Memory: 4096 MB [6-6-6-18 DDR2]
CPU Q6700 Quad
Standard FAN and Heatsink
Whats strange is that the FAN was running at 3500RPM last night just transcoding one of the files (front panel figures for last night below). I took the CPU out last night and replaced it with the E6700, today I put back the Q6700 but this time used Artic Silver 5 Thermal Compound. However, I don't see how the Artic Silver 5 has made up the difference!
Figures for lastnight:
Fan SYS 1739 RPM OK
Fan CPU 3443 RPM OK
Temp CPU 51 C / 123 F [Normal 0-85 C / 32-185 F] OK
I'm going to monitor the situation and see where is takes me. I might invest in a better fan/heatsink at some point - any suggestions?
Also, If anyone can suggest alternative tests or stats to compare ? I will provide the output for all in this tread
so far its looking good :D
Fan SYS 1339 RPM OK
Fan CPU 2163 RPM OK
CPU Q6700 Quad
Fan SYS 1739 RPM OK
Fan CPU 3443 RPM OK
