cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Korky
Jun 26, 2012Aspirant
No it hasnent fried the ultra yet, but I'm not convinced! The stock cooler/fan is just not upto the job, as one of the previous forum user pointed out. Im not running it for long periods so not a problem for me. I wouldn't keep it in my ultra if i was running it 24/7. So to answer your question, no I wouldnt put the q7600 in just yet. I am looking at replacing the heatsink(one should be arriving anytime now) and the fan. I will run more tests before I leave the CPU in for longer periods.
I will keep you posted.
