cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
iwaleed
Jul 03, 2012Initiate
I test today E7400 2.8GHz SLGW3 this support (VT-x) and also work with Pro 6 Bios version (07/26/2010 FLAME6-MB V2.0) also work with Ultra 6 Plus after upgrade the Bios version to (07/26/2010 FLAME6-MB V2.0)
I noticed the Temp. is lower than E6700 in the same system difference about 10ºC
E7400 Temperature
E6700 Temperature
rocessor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 23
model name : Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz
stepping : 10
cpu MHz : 2793.002
cache size : 3072 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 xsave lahf_lm dts tpr_shadow vnmi flexpriority
bogomips : 5586.00
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 23
stepping : 10
cpu MHz : 2793.002
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 5585.02
clflush size : 64
power management:
E7400 Temperature
/sys/devices/platform/coretemp.0/temp1_max:76000
/sys/devices/platform/coretemp.0/temp1_label:Core 0
/sys/devices/platform/coretemp.0/temp1_crit_alarm:0
/sys/devices/platform/coretemp.0/temp1_input:34000
/sys/devices/platform/coretemp.0/temp1_crit:100000
/sys/devices/platform/coretemp.1/temp1_max:76000
/sys/devices/platform/coretemp.1/temp1_label:Core 1
/sys/devices/platform/coretemp.1/temp1_crit_alarm:0
/sys/devices/platform/coretemp.1/temp1_input:33000
/sys/devices/platform/coretemp.1/temp1_crit:100000
E6700 Temperature
/sys/devices/platform/coretemp.0/temp1_max:80000
/sys/devices/platform/coretemp.0/temp1_input:44000
/sys/devices/platform/coretemp.1/temp1_max:80000
/sys/devices/platform/coretemp.1/temp1_input:43000
